64-bit Win7. Local drive for development. I'm not sure how I should "clean" my machine. I'm not quite ready to wipe the hard drive and reinstall everything. 🙂 Do the pdb files that come with the dlls mean I can stop inside CloseGeodatabase and see where it's stuck? I haven't been able to so far by telling VS the location of the symbol files. Currently when I break in the debugger it stops in thread-related code (lock) or in the function CatalogRegistry::CatalogRef::Release() under CatalogRegistry::Unregister() . That much in can see in the call stack.
I just unzipped the .zip file on a clean machine. Are you using the 32bit or 64bit version of Windows 7? Are you using a local drive or a network drive?
Using a fresh install of the VS2008 version of the API I don't see any slowdown in any of the samples. I'm using a Windows 7.
How big is your file geodatabase? Have you seen the same behavior with the samples?
We haven't seen this issue. What environment (VS2008, VS2010, 32bit/64bit, Linux) are you using. How long of a lag are you seeing?
