I am wanting to set up Symbology on my points, referencing two different attributes.
I was using QGIS and could easily do this with Rule-Based Symbology. QGIS Screenshot included.
What would be the method to do it in Pro?
@ScottLThompson , yes this is possible to symbolise features based off 2 or more attribute fields ArcGIS Pro.
You need to select the Unique Values options, here you can either select the fields you want to combine or create an arcade expression to create custom groups of data which you want to symbolise.
https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/unique-value.htm
Esri also has a blog describing the arcade process: https://support.esri.com/en/technical-article/000017852
Hope this helps 🙂
