I have some problems with assettype and assetgroup names. I used "/" character in my assetgroup and assetype name. For example:
- Valve/valvola [assetgroup]
- open/aperta [assettype]
but when I use the following tool "set subnetwork definition" I have the following error:
- ERROR 001958: No valid asset group was found. [Valve/valvola / open/aperta]
so I presume that "/" is a special character not allowed.
I tried to use the following steps in order to remove the "/" from my utility network:
1) "export asset package" and no errors occur.
2) "add rename table" but the following error occour:
Create Asset Package Rename Table
Parameters
Asset Package C:\ArcGIS\Hydrogis_v1\exportAssetPackage\AlperiaGreenpower.gdb
Rename Fields
Output Package
Messages
Start Time: giovedì 3 novembre 2022 10:15:33
ArcGIS Pro 2.9.5.32739
untools 2.9.3
Executing from ArcGIS Pro, 2 map(s), activeMap = True
Parallel processing enabled: 12
The asset package has the following errors (56/56):
Item Field OID Value Message Level
0 B_Rules from_terminal 7.0 Hydroelectric/Device/Absperrorgan / valvola/absperrorgan / organo intercettazione/None Terminal name is required for this asset group / asset type error
1 B_Rules from_terminal 8.0 Hydroelectric/Device/Absperrorgan / valvola/absperrorgan / organo intercettazione/None Terminal name is required for this asset group / asset type error
2 B_Rules from_terminal 9.0 Hydroelectric/Device/Absperrorgan / valvola/absperrorgan / organo intercettazione/None Terminal name is required for this asset group / asset type error
3 B_Rules from_terminal 10.0 Hydroelectric/Device/Absperrorgan / valvola/absperrorgan / organo intercettazione/None Terminal name is required for this asset group / asset type error
4 B_Rules from_terminal 11.0 Hydroelectric/Device/Absperrorgan / valvola/absperrorgan / organo intercettazione/None Terminal name is required for this asset group / asset type error
5 B_Rules from_terminal 12.0 Hydroelectric/Device/Absperrorgan / valvola/absperrorgan / organo intercettazione/None Terminal name is required for this asset group / asset type error
6 None None None HydroelectricDevice/Absperrorgan / valvola "/" should not be used in AssetGroup names warning
7 None None None HydroelectricDevice_valvola_AssetType (1:absperrorgan / organo intercettazione) "/" should not be used in AssetType names warning
8 None None None HydroelectricDevice_valvola_AssetType (2:ohne wiederkehrl / di non ritorno) "/" should not be used in AssetType names warning
9 None None None HydroelectricDevice/Wasserschloss / pozzo "/" should not be used in AssetGroup names warning
10 None None None HydroelectricDevice_pozzo_AssetType (1:piezometrisch / piezometrico) "/" should not be used in AssetType names warning
11 None None None HydroelectricDevice/Becken / bacino "/" should not be used in AssetGroup names warning
12 None None None HydroelectricDevice_bacino_AssetType (1:Becken / bacino) "/" should not be used in AssetType names warning
13 None None None HydroelectricDevice/Siphon / sifone "/" should not be used in AssetGroup names warning
14 None None None HydroelectricDevice_sifone_AssetType (1:oberirdisch / fuori terra) "/" should not be used in AssetType names warning
15 None None None HydroelectricDevice_sifone_AssetType (2:underirdisch / interrato) "/" should not be used in AssetType names warning
16 None None None HydroelectricDevice_sifone_AssetType (3:zum Ableitungsstollen / per galleria di derivazione) "/" should not be used in AssetType names warning
17 None None None HydroelectricDevice/Wasserfassung / presa sussidiaria "/" should not be used in AssetGroup names warning
18 None None None HydroelectricDevice_presasussidiaria_AssetType (1:wasserfassung / presa sussidiaria) "/" should not be used in AssetType names warning
19 None None None HydroelectricDevice/Messpunkt / punto di misura "/" should not be used in AssetGroup names warning
20 None None None HydroelectricDevice_puntodimisura_AssetType (1:Messpunkt / punto di misura) "/" should not be used in AssetType names warning
21 None None None HydroelectricDevice/Zugangsfenster / finestra di accesso "/" should not be used in AssetGroup names warning
22 None None None HydroelectricDevice_finestradaccesso_AssetType (1:Zugangsfenster / finestra di accesso) "/" should not be used in AssetType names warning
23 None None None HydroelectricDevice/Wasserkraftwerk / centrale "/" should not be used in AssetGroup names warning
24 None None None HydroelectricDevice_centrale_AssetType (1:Wasserkraftwerk / centrale) "/" should not be used in AssetType names warning
25 None None None HydroelectricDevice/Panzertür / porta stagna "/" should not be used in AssetGroup names warning
26 None None None HydroelectricDevice_portastagna_AssetType (1:Panzertür / porta stagna) "/" should not be used in AssetType names warning
27 None None None HydroelectricDevice/Mannloch / passouomo "/" should not be used in AssetGroup names warning
28 None None None HydroelectricDevice_passouomo_AssetType (1:Mannloch / passouomo) "/" should not be used in AssetType names warning
29 None None None HydroelectricDevice/Inspektionsschacht / pozzetto "/" should not be used in AssetGroup names warning
30 None None None HydroelectricDevice_pozzetto_AssetType (1:Inspektion / di ispezione) "/" should not be used in AssetType names warning
31 None None None HydroelectricDevice/Pumpe / pompa "/" should not be used in AssetGroup names warning
32 None None None HydroelectricDevice_pompa_AssetType (1:oberirdisch / fuori terra) "/" should not be used in AssetType names warning
33 None None None HydroelectricDevice_pompa_AssetType (2:underirdisch / interrato) "/" should not be used in AssetType names warning
34 None None None HydroelectricDevice_pompa_AssetType (3:zum Ableitungsstollen / per galleria di scolo) "/" should not be used in AssetType names warning
35 None None None HydroelectricDevice/Turbine / turbina "/" should not be used in AssetGroup names warning
36 None None None HydroelectricDevice_turbina_AssetType (1:Turbine / turbina) "/" should not be used in AssetType names warning
37 None None None HydroelectricDevice/Ablass / scarico "/" should not be used in AssetGroup names warning
38 None None None HydroelectricDevice_scarico_AssetType (1:Ablass / scarico) "/" should not be used in AssetType names warning
39 None None None HydroelectricDevice/Überlauf / sfioro "/" should not be used in AssetGroup names warning
40 None None None HydroelectricDevice_sfioro_AssetType (1:Überlauf / sfioro) "/" should not be used in AssetType names warning
41 None None None HydroelectricDevice/Entlüfter / sfiato "/" should not be used in AssetGroup names warning
42 None None None HydroelectricDevice_sfiato_AssetType (1:Entlüfter / sfiato) "/" should not be used in AssetType names warning
43 None None None HydroelectricDevice/DMV / DMV "/" should not be used in AssetGroup names warning
44 None None None HydroelectricDevice_DMV_AssetType (1:DMV / DMV) "/" should not be used in AssetType names warning
45 None None None HydroelectricDevice/Stausee / diga "/" should not be used in AssetGroup names warning
46 None None None HydroelectricDevice_diga_AssetType (1:Stausee / diga) "/" should not be used in AssetType names warning
47 None None None HydroelectricLine/Rohrleitung / condotta "/" should not be used in AssetGroup names warning
48 None None None HydroelectricLine_condotta_AssetType (1:oberirdisch / fuori terra) "/" should not be used in AssetType names warning
49 None None None HydroelectricLine_condotta_AssetType (2:underirdisch / interrata) "/" should not be used in AssetType names warning
50 None None None HydroelectricLine/Tunnel / tunnel "/" should not be used in AssetGroup names warning
51 None None None HydroelectricLine_tunnel_AssetType (1:Drucksstollen / galleria in pressione) "/" should not be used in AssetType names warning
52 None None None HydroelectricLine_tunnel_AssetType (2:Zugangsstollen / galleria di accesso) "/" should not be used in AssetType names warning
53 None None None HydroelectricLine/Kanal / canale "/" should not be used in AssetGroup names warning
54 None None None HydroelectricLine_canale_AssetType (1:Freispiegelleitung / canale gronda) "/" should not be used in AssetType names warning
55 None None None HydroelectricLine_canale_AssetType (2:Ablasstollen / canale di scarico) "/" should not be used in AssetType names warning
Failed to execute (CreateRenameTable).
Failed at giovedì 3 novembre 2022 10:15:35 (Elapsed Time: 2,89 seconds)
I'm using ArcGIS Pro 2.9.5 with utility network v5 on file geodatabase. how I can continue my work? I spent severals weeks to configure my utility network without having errors before that ("/" character).
