ArcMap, with the Production Mapping extension, has a tool called Set Origin Vertex which allows you to change the origin vertex of a polygon feature.
https://desktop.arcgis.com/en/arcmap/latest/extensions/production-mapping/set-origin-vertex.htm
This tool is missing in Pro and there doesn't appear to be an equivalent. Can this tool please be carried across to Pro, preferably as a general tool and not part of an extension.
@DavidGifford In Pro, what workflow are you attempting that requires this ability?
Hi Scott
As an example, when applying for certain types of mining tenements a datum/origin is required. This is marked on the ground with a post and on the application form as the start point for a list of coordinates for each vertex. If the polygon isn't created correctly, or the datum has to change due to a feature on the ground, altering the polygon origin with this tool makes it much easier to do.
RegardsDavid
This Idea has been implemented in ArcGIS Pro 3.2. Please see the What's New documentation for more new features in Pro 3.2.
The Your Ideas in ArcGIS Pro 3.2 blog and video have been posted to the Esri Community blog. You can take a look at these to see your idea and all others that were implemented in this release of ArcGIS Pro.
Here is the link to the help: https://pro.arcgis.com/en/pro-app/latest/help/editing/set-the-origin-vertex-of-a-polygon.htm
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
