for fc in listFCs: fcFieldList = arcpy.ListFields(fc) if (valueField in fcFieldList) & (classField in fcFieldList): rows = arcpy.UpdateCursor(fc) for row in rows: row.setValue(classField, calc(row.getValue(valueField))) # looks complex, but is just getting the value from valueField, passing it to CALC then writing the output to the classField rows.updateRow(row) try: del row except NameError: pass del rows
if len(classBreaks)- 1 != len(classValues): arcpy.AddError('Class Values and Class Breaks must be the same length.')
import arcpy def calc(x): # function that does the calculation '''calc(x) iterates through the classBreaks until it finds the bounding values of the input number, then returns the corresponding value from classVals ''' for i in xrange(len(classBreaks)-1): if classBreaks <= x < classBreaks[i+1]: return classValues elif x == classBreaks[-1]: # x equals the last value - wouldn't work above, as it is less than... return classValues[-1] return None # return something if the value isn't within the range, can be whatever you want - None will be converted to Arc NULL, but you could have 'No Class' or something like that, if you wanted... Geodatabase = arcpy.GetParameterAsText(0) # Location of Geodatabase classBreaks_str = arcpy.GetParameterAsText(1) # Break values (comma separated values) classValues_str = arcpy.GetParameterAsText(2) # Classes (comma separated values) to be returned, must correspond with the Break values valueField = arcpy.GetParameterAsText(3) # Field to be calculated on classField = arcpy.GetParameterAsText(4) # Field for results to go in classBreaks_str = '[' + classBreaks_str + ']' # add square brackets, so they look like lists classValues_str = '[' + classValues_str + ']' try: classBreaks = eval(classBreaks_str) except SyntaxError: arcpy.AddError('Class Breaks was entered incorrectly; values must each seperated by a comma.') except NameError: arcpy.AddError('Class Breaks was entered incorrectly; values must either be numbers or, if strings, within quotes.') try: classValues = eval(classValues_str) except SyntaxError: arcpy.AddError('Class Values was entered incorrectly; values must each seperated by a comma.') except NameError: arcpy.AddError('Class Values was entered incorrectly; values must either be numbers or, if strings, within quotes.') if len(classBreaks) != len(classValues): arcpy.AddError('Class Values and Class Breaks must be the same length.') arcpy.env.workspace = Geodatabase # set the workspace listFCs = arcpy.ListFeatureClasses('*') for fc in listFCs: rows = arcpy.UpdateCursor(fc) for row in rows: row.setValue(classField, calc(row.getValue(valueField))) # looks complex, but is just getting the value from valueField, passing it to CALC then writing the output to the classField rows.updateRow(row) try: del row except NameError: pass del rows
import arcpy import arcgisscripting gp = arcgisscripting.create() Feature_Class = gp.GetParameterAsText(0) # Location of Geodatabase classBreaks_str = gp.GetParameterAsText(1) # Break values (comma separated values) classValues_str = gp.GetParameterAsText(2) # Classes (comma separated values) to be returned, must correspond with the Break values valueField = gp.GetParameterAsText(3) # Field to be calculated on classField = gp.GetParameterAsText(4) # Field for results to go in classBreaks_str = '[' + classBreaks_str + ']' # add square brackets, so they look like lists classValues_str = '[' + classValues_str + ']' try: classBreaks = eval(classBreaks_str) except SyntaxError: arcpy.AddError('Class Breaks was entered incorrectly; values must each seperated by a comma.') except NameError: arcpy.AddError('Class Breaks was entered incorrectly; values must either be numbers or, if strings, within quotes.') try: classValues = eval(classValues_str) # I called this classVals in the previous post except SyntaxError: arcpy.AddError('Class Values was entered incorrectly; values must each seperated by a comma.') except NameError: arcpy.AddError('Class Values was entered incorrectly; values must either be numbers or, if strings, within quotes.') if len(classBreaks) != len(classValues): arcpy.AddError('Class Values and Class Breaks must be the same length.') def calc(x): # function that does the calculation '''calc(x) iterates through the classBreaks until it finds the bounding values of the input number, then returns the corresponding value from classVals ''' for i in xrange(len(classBreaks)-1): if classBreaks <= x < classBreaks[i+1]: return classValuess elif x == classBreaks[-1]: # x equals the last value - wouldn't work above, as it is less than... return classValues[-1] return None # return something if the value isn't within the range, can be whatever you want - None will be converted to Arc NULL, but you could have 'No Class' or something like that, if you wanted... listFCs = arcpy.ListFeatureClasses("*") for fc in listFCs: rows = arcpy.UpdateCursor(fc) for row in rows: row.classField = calc(row.valueField) rows.updateRow(row) try: del row except NameError: pass del rows
<type 'exceptions.RuntimeError'>: Row: Field valueField does not exist Failed to execute (Classify)
# presumably you are bringing in other variables, you only mentioned 0 then jumped to 3 - the parameter numbers must go up in order... classBreaks_str = gp.GetParameterAsText(3) # Break values (comma separated values) classValues_str = gp.GetParameterAsText(4) # Classes (comma separated values) to be returned, must correspond with the Break values valueField = gp.GetParameterAsText(5) # Field to be calculated on classField = gp.GetParameterAsText(6) # Field for results to go in
classBreaks_str = '[' + classBreaks_str + ']' # add square brackets, so they look like lists classValues_str = '[' + classValues_str + ']' try: classBreaks = eval(classBreaks_str) except SyntaxError: arcpy.AddError('Class Breaks was entered incorrectly; values must each seperated by a comma.') except NameError: arcpy.AddError('Class Breaks was entered incorrectly; values must either be numbers or, if strings, within quotes.') try: classValues = eval(classValues_str) # I called this classVals in the previous post except SyntaxError: arcpy.AddError('Class Values was entered incorrectly; values must each seperated by a comma.') except NameError: arcpy.AddError('Class Values was entered incorrectly; values must either be numbers or, if strings, within quotes.') if len(classBreaks) != len(classValues): arcpy.AddError('Class Values and Class Breaks must be the same length.') # rest of processing (previous posts) goes here...
del row, rows
Pre-Logic Script Code: classBreaks = [0, 0.2, 0.4, 0.6, 0.8, 1.0, 1.2, 1.4, 1.6, 2] # defines where the values for the breaks are classVals = [1, 2, 3, 4, 5, 4, 3, 2, 1] # what should be returned - corresponds to the position of the value in classBreaks def calc(x): # function that does the calculation '''calc(x) iterates through the classBreaks until it finds the bounding values of the input number, then returns the corresponding value from classVals ''' for i in xrange(len(classBreaks)-1): if classBreaks <= x < classBreaks[i+1]: return classVals elif x == classBreaks[-1]: # x equals the last value - wouldn't work above, as it is less than... return classVals[-1] return None # return something if the value isn't within the range, can be whatever you want - None will be converted to Arc NULL, but you could have 'No Class' or something like that, if you wanted... ClassField= calc(!Value!)
import arcpy classBreaks = [0, 0.2, 0.4, 0.6, 0.8, 1.0, 1.2, 1.4, 1.6, 2] # defines where the values for the breaks are classVals = [1, 2, 3, 4, 5, 4, 3, 2, 1] # what should be returned - corresponds to the position of the value in classBreaks def calc(x): # function that does the calculation '''calc(x) iterates through the classBreaks until it finds the bounding values of the input number, then returns the corresponding value from classVals ''' for i in xrange(len(classBreaks)-1): if classBreaks <= x < classBreaks[i+1]: return classVals elif x == classBreaks[-1]: # x equals the last value - wouldn't work above, as it is less than... return classVals[-1] return None # return something if the value isn't within the range, can be whatever you want - None will be converted to Arc NULL, but you could have 'No Class' or something like that, if you wanted... arcpy.env.workspace = r"C:\temp\python\test.gdb" listFCs = arcpy.ListFeatureClasses("*") for fc in listFCs: rows = arcpy.UpdateCursor(fc) for row in rows: row.ClassField = calc(row.Value) rows.updateRow(row) del row, rows
import arcpy from arcpy import env env.workspace = r"C:\temp\python\test.gdb" lstFCs = arcpy.ListFeatureClasses("*") for fc in lstFCs: rows = arcpy.UpdateCursor(fc) try: for row in rows: if row.Value >= 0.0 and row.Value <= 0.2: row.Class = 1 if row.Value > 0.2 and row.Value <= 0.4: row.Class = 2 if row.Value > 0.4 and row.Value <= 0.6: row.Class = 3 if row.Value > 0.6 and row.Value <= 0.8: row.Class = 4 if row.Value > 0.8 and row.Value <= 1.0: row.Class = 5 if row.Value > 1.0 and row.Value <= 1.2: row.Class = 4 if row.Value > 1.2 and row.Value <= 1.4: row.Class = 3 if row.Value > 1.4 and row.Value <= 1.6: row.Class = 2 if row.Value > 1.6 and row.Value <= 2.0: row.Class = 1 rows.updateRow(row) except RuntimeError: pass del row, rows
