I saw it's possible to collect oriented imagery via Quick Capture. Is it also possible using Field Maps ?
Thank you !
It looks like this one may do it but not much info to go on in the help.
AttachmentDefines information about attachments returned from feature service queries. These are fetched using the Attachments() function.
Property Type Descriptionid number The ID of the attachment.name text The file name of the attachment, including the file extension.exifInfo Array An array containing the Exif metadata of the attachment.
I use the ExifTool https://exiftool.org/ and the Python wrapper for it https://pypi.org/project/PyExifTool/ I pull the exif I need out after I export them.
Hope that helps
Hi Doug,
Our goal is to fill a field in a feature Class using Exif info when features are collected with attachments using Field Maps. Quick capture designer allows to fill fields values with informations about the device and the camera but I didn't saw anything alike in Field Maps
Thanks !
I used the Orientated Imagery tools and was able to get any old photo with Exif to go. Why would it be app specific?
We did find that you must set iOS to to Most Compatible in the photos setting otherwise all the exif gets stripped.
Not sure what you mean here?
Finally we found it's possible with Survey123 using the pulldata function on exif infos.
Still no idea about Field Maps... maybe with Arcade ?
I thought it just uses the Exif info which should be in all photos? I would like to know.
