我查看了文档,但我不知道如何正确完成它。
添加地图,使用其他基础地图。 底图服务有哪些要求?
We support all image tile layers as basemaps other than the default ones we provided in the current plug-in. You can find more basemaps from Living Atlas or ArcGIS Online and use this filter: type:"Map Service" AND typekeywords:"Tiled" to filter image tile layers. If there's data loading issues, you may check the viewstate logging for issues. One common reason is data projection. Please refer this doc page for more info.
I was using part of the base map service. Unreal engine will issue an error message='Invalid argument.' additional-message='tile info origin must have a spatial reference.
Have something more detailed? I entered the website you provided, but don't know which url I can put into the source input box.All I do is failed.
