We are operating an on-prem, federated, 10.9.1 Portal with a 'primary' and 'secondary' environments. We use WebGIS DR to create a backup of the primary, and use it to restore the secondary (daily). (When necessary we fail over from the primary to the secondary when required via Netscaler and Host file changes.)
The colleague who initially setup our WebGIS DR configuration left. We have noticed that each restore to our secondary creates a PostgreSQL db folder in the Portal server install root on the secondary (which in our case is
\arcgisportal\. I cannot find where this is configured anywhere in the webgisdr.properties (which is stored in
\propfiles in our environment). Is there a WebGIS DR default setting that specifies the root \arcgisportal\ directory? More importantly, can we simply delete all of these old PostgreSQL directories? They're only a few hundred mb each, but are a bit of a nuisance. Thanks
Justin
