# Configure the Oracle database, adding an sde user and Setting variables for the sde OS user on Linux or UNIX if necessary.
sdesetup -o install -d Oracle11g
If your database management system (DBMS) is installed on one server and ArcSDE is installed on a separate Windows server, you cannot run the ArcSDE Post Installation wizard to create the service. Instead, you must use the sdeservice command to create an ArcSDE service if you want to use one.
