Hi All,
Is there a significant difference between ArcMap 10.7 Vertex Snapping and PRO 2.9 Vertex Snapping? eg differences on edit vertex tool values, coding, syntax, or snapping tolerances are what I am trying to pin down.
It is too inconsistent to make a tech support ticket yet but I am occasionally encountering polygons that appear to "unsnap" at certain vertices after scheduled version rec and post operations. I am trying to figure out if it is something in the backend I can't see either in PRO or Arc or the jump of data between the two platforms so I can provide a workaround or solution to my team members having to return and snap their polygon vertices back in place every now and then.
Any info or guidance helps, kind of a niche or version user specific thing so there's not much to go off of for documentation,
Many thanks,
