Good Morning,
We are trying to set the default Coordinate in the Coordinate Conversion Widget to something other than XY. Is this possible? I see nothing in the documentation. I would rather have MGRS instead.
When you enter edit mode for the app, hover your mouse over the Coordinate Conversion widget, and select the pencil, it allows you to select from the list of conversions you want to use. If you're only interested in MGRS. you can select it and deselect everything else.
Is this what you're looking for, or do you want to have everything available and reorder them so MGRS is at the top?
Are you using WAB Developer Edition or just creating the app in your AGOL portal ?I don't see a function for reordering them in the standard widget editing functionality, which might mean that you would need to be using DE so you can tweak the code in the files for the widget.
We are using the ArcGIS API for JavaScript
CoordinateConversion widget | Sample Code | ArcGIS API for JavaScript 4.24 | ArcGIS Developers
