I'm trying to add a date field without it taking too long. Using arcpy.da.UpdateCursor took forever, so I'm trying Add field and calculate field ... which I cannot seem to get working! Any advice is appreciated! ArcGIS 2.9. Below is part of my code.
Thank you - Daniel
import arcpy, os, sys
import datetime
PatrolDateCalc = datetime.date(2022, 9, 19)
fc = oh
field = "PatrolDate"
if arcpy.ListFields(fc, field) == True:
Print ("PatrolDate" + fc + "field already present")
else:
arcpy.management.AddField(fc, field, "DATE", "10", "", "", "Patrol Date", "", "NON_REQUIRED")
arcpy.management.CalculateField(fc, field, PatrolDateCalc, "PYTHON3", "", "DATE", "NO_ENFORCE_DOMAINS")
fc = ug
else:
In [14]:
Line: arcpy.management.CalculateField(fc, field, PatrolDateCalc, "PYTHON3", "", "DATE", "NO_ENFORCE_DOMAINS")
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py, in CalculateField:
Line 5588: raise e
Line 5585: retval = convertArcObjectToPythonObject(gp.CalculateField_management(*gp_fixargs((in_table, field, expression, expression_type, code_block, field_type, enforce_domains), True)))
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py, in <lambda>:
Line 512: return lambda *args: val(*gp_fixargs(args, True))
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000840: The value is not a SQL Expression.
Failed to execute (CalculateField).
