I would like to download and visualize the following webscene.
OpenStreetMap 3D Trees (Realistic)
This is a scene layer not a web scene and there are some known issues surrounding opening certain layers using this Open in ArcGIS Pro workflow.
I would recommend either adding this layer in ArcGIS Pro through the Catalog Pane Portal tab or copying the URL and going to Add Data > Add Data by Path > https://basemaps3d.arcgis.com/arcgis/rest/services/OpenStreetMap3D_Trees_Realistic_v1/SceneServer
The data in this layer is dependent on what's available in the open source OSM database. I'm not sure which area you are looking at but I looked in Miami and didn't see any trees render there so this may not work for you.
thanks,
Andrew
