@IsmaelChivite
[Errno 2] No such file or directory: '/tmp/survey123-form-converter/outputs/xls2xform/_requestId_/' with the name of the survey.xlsx.xml
This is occurring when the XLSForm is saved. It will get to the converting stage, then fail. Sometimes if I press save again, sometimes it'll error several times in a row. It's consistently intermittent (if that's such a thing). I can usually get it to save if I'm persistent, but when doing development on a big survey where I need to see the changes I've been making in the survey, it's becoming annoying and time consuming. I've searched and can't seem to find any related questions/posts. Does anybody have any ideas what might be causing this? I've even created a new survey and used my XLS document in the new survey and get the same results. Publishing the survey succeeds.
I'm at a bit of a loss...
Thanks for any help.
