My fellow web developers use ImageryTileLayer from ArcGIS API for JavaScript. I was unable to find anything similar in iOS SDK. How do we replace ImageryTileLayer?
The equivalent in ArcGIS Runtime is the AGSImageServiceRaster class, which you display via the AGSRasterLayer class:
Add raster data | ArcGIS Runtime API for iOS | ArcGIS Developers
ArcGIS Runtime SDK for iOS: AGSImageServiceRaster Class Reference
ArcGIS Runtime SDK for iOS: AGSRasterLayer Class Reference
Hi, Michael! Thank you for your reply!I tried to use the AGSRasterLayer & AGSImageServiceRaster, but it doesn't work for me. When I use image service URL from the AGSRasterLayer example on github, it works fine, but when I try the URL my teammates use on the web with ImageryTileLayer, the layer is not displayed. I also noticed, that the ImageServer info structure and attributes differ between these URLs.example URL: https://gis.ngdc.noaa.gov/arcgis/rest/services/bag_hillshades_subsets/ImageServer
URL we use: https://tiledimageservices.arcgis.com/P3ePLMYs2RVChkJx/arcgis/rest/services/GEBCO_2021_Bathymetry/ImageServer
So it brings us back to the original question: maybe I should use other layer class?
I just gave this a try with another Runtime SDK - .NET - and it worked fine. But I noted:
Map = new Map(BasemapStyle.ArcGISDarkGray); ImageServiceRaster imageServiceRaster = new ImageServiceRaster(new Uri("https://gis.ngdc.noaa.gov/arcgis/rest/services/bag_hillshades_subsets/ImageServer")); RasterLayer rasterLayer = new RasterLayer(imageServiceRaster); await rasterLayer.LoadAsync(); Map.InitialViewpoint = new Viewpoint(rasterLayer.FullExtent); Map.OperationalLayers.Add(rasterLayer);
Hi, @MichaelBranscomb!
The URL in your code sample works for me too, but this one doesn't.
According to Nicholas-Furness in this answer, the issue is related to LERC format, which is not supported for visualization by the runtime.
