Hello! Maybe anybody knows how to use the power operator to create a formula to calculate an index based on the image bands. For example, I try to use formula: 0.5847*((B1**(-0.1294))*(B2**0.3389)*(B3**(-0.3118))).
That should work, if you make the assignments
B1 = Raster('rasterFile\Band_1')B2 = Raster('rasterFile\Band_2')B3 = Raster('rasterFile\Band_3')index = 0.5847*((B1**(-0.1294))*(B2**0.3389)*(B3**(-0.3118)))
— Andy
Thank you for the solution. Can you explain where to create it, please? I mean what tool I should use if I work at the ArcGIS Pro 2.9.3.
Simplest is the Python window, or if you want to save it for future reference you could create a Jupyter notebook; both are available in the ribbon Analysis. If you plan to use it repeatedly, though, I’d create a script in a toolbox, which would allow you to easily load different files as arguments:https://pro.arcgis.com/en/pro-app/2.9/arcpy/geoprocessing_and_python/adding-a-script-tool.htm
Oddly these instructions are incomplete; go to the list item Execution, and you'll find the beginning of a script to which you can add the code above, with 'rasterFile' returned in the line:
param0 = arcpy.GetParameterAsText(0)
