I am trying to parse values for my NENA NextGen 9-1-1 street name fields by using the VBScript InStr operator. For example, if the original street name field contains a USPS Publication 28 Street Suffix the expression should be able to find that prefix/suffix in the name and put it in the Pre-Type or Post-Type field, find any pre- or post-separators, and then remove the suffix and separators from the Street Name field . Here's what I have so far, although I do not get results with the Pre-Type ValueInfo expressions I have listed. I'm unsure if this is a problem with the InStr operator itself because a similar expression using Left does work.
Original Road Name Fields and Values
ROADNAME: Old US Highway 41A
NENA Road Name Fields and (Expected) Values
St_PreMod : Old
St_PreDir: <Null>
St_PreTyp: United States Highway
St_Name: 41
St_PosType: <Null>
St_PosDir: <Null>
St_PosMod: Alternate
I will list the following lines in the Attribute Assistant in order of their Rule Weights so they go in order:
Street Name (This works)
- TableName: MasterStreetName
- FieldName: St_Name
- ValueMethod: FIELD
- ValueInfo: ROADNAME
- RuleWeight: 985
- Comments: Copies the ROADNAME to NENA St_Name
Street Post-Modifier (This works)
- FieldName: St_PosMod
- ValueMethod: EXPRESSION
- ValueInfo: IIF(InStr([St_Name], "41A"), "Alternate", [St_PosMod])
- RuleWeight: 984
- Comments: If the St_Name contains 41A, set the St_PosMod to Alternate
Street Pre-Modifier (This works)
- FieldName: St_PreMod
- ValueInfo: IIF(Left([St_Name], 4) = "Old ", "Old", "<Null>")
- RuleWeight: 983
- Comments: If the St_Name starts with Old + a space, set the St_PreMod to Old
Street Pre-Type (Neither method works)
- FieldName: St_PreTyp
- ValueInfo:
- IIF(InStr([St_Name], "US Highway "), "United States Highway", "")
- IIF(InStr([St_Name], "US Highway "), "United States Highway", [St_PreTyp])
- RuleWeight: 983
- Comments: If the St_Name starts with the NENA type, set the St_PreTyp to that value
- ValueInfo: TRIM(Replace([St_Name], "Old ", ""))
- RuleWeight: 982
- Comments: Replace the equivalent NENA pre- or post-type in the St_Name with nothing
- ValueInfo: TRIM(Replace([St_Name], "US Highway ", ""))
- RuleWeight: 982
- ValueInfo: TRIM(Replace([St_Name], "41A", "41"))
- RuleWeight: 981
- Comments: Replace 41A with 41.
NENA Road Name Fields and (Resultant) Values
St_PreMod : Old
St_PreDir: <Null>
St_PreTyp: <Null>
St_Name: 41
St_PosType: <Null>
St_PosDir: <Null>
It looks like the InStr operator fails. This is not the only situation I have this problem. We have Spanish streets names that need their pre-types and separators parsed as well. What is odd is that I have two identical expressions that have different results:
Street Pre-Type (Different Results)
- ValueInfo:
- IIF([St_Name] = "Via Del Mar", "del", "<NULL>") Does not work
- IIF([St_Name] = "Vista Del Rio", "del", "<NULL>") This works
- RuleWeight: 983
The InStr operator is inconsistent buts tends to not work the way I have them coded.
Any help is welcome.
Thank you.
