while I imported a shape file to GDB the following Message appear and GDB contains Dissapear
Failed to connect to database.Underlying database error occurred.Unrecognized database format (Our Database's path and name.mdb)Any suggestions are gladly welcome.
Frequently asked questions—ArcGIS Pro | Documentation
Can I use personal geodatabases (.mdb) as data sources for ArcGIS Pro?
Personal geodatabases can only be viewed in ArcGIS Pro. Personal geodatabase datasets can't be used as inputs to geoprocessing tools. Similarly, output datasets can't be stored in personal geodatabases. ArcGIS Pro supports the following types of geodatabases: file geodatabases, mobile geodatabases, and enterprise geodatabases.
Thank you very much @AndyAnderson . i will try ..
A file with the format .mdb is not a shapefile, it’s a “personal geodatabase” in the format of a Microsoft Access database. The solution is to use the 32-bit version of ArcMap to convert it to a file geodatabase and then reopen in ArcGIS Pro:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/tool-errors-and-warnings/001001-010000/tool-errors-and-warnings-01301-01325-001324.htm
