After updating from 3.1 to 3.2 labels in .aix files in Illustrator don't show up as they should.
The labeled data we used is OSM roads and software Arcgis Pro 3.
Especially problematic with curved labels
In the attachments we've added the .aix in a compressed zip
Hi @EMKcartografie ,
Sorry for the inconvenience and thank you for adding your AIX. I took a look at the attached file and I can partially reproduce your issue. Is it possible for you to send along a little bit more info so we can take a deeper look at this? If you could attach your pro map package here that would be very helpful. If that's not possible a url to the specific OSM road layer you're using in this AIX would also work.
Best,
Anna
Hi Anna,
Thank you for your quick reply. Sorry for my late response...
This OSM road layer used to did the trick for me when labeling.
https://services-eu1.arcgis.com/zci5bUiJ8olAal7N/arcgis/rest/services/OSM_Highways_EU/FeatureServer
In previous versions of the plugin I didn't experience this issue. In the end I used a different source for labeling which worked for me.
https://basisregistraties.arcgisonline.nl/arcgis/rest/services/BRT/BRT_TOP10NL/FeatureServer
Happy with the Adobe plugin overall and the progress that has been made in developing this plugin.
