At some point in the past week, both my Survey123 Connect and Field App have become essentially unusable. Opening up either of them involves waiting sometimes 10 minutes to get a response -- all the while I'm waiting, I get the Windows warning that they are Not Responding. After the initial load, if I make it through that, in Connect, I can click a survey I want to work on, but the software then hangs again and I get the "Not responding" error on Windows. I've never made it long enough to see the survey actually load. The Field App is much the same way.
I've tried uninstalling Connect and reinstalling with the newest version, but even the executable for the installer runs into the same issue of hanging and "Not Responding". I've checked my firewall and let Survey123 through, but that hasn't solved anything.
I have not run into this issue with ArcGIS Pro, if that's relevant -- that software loads and runs fine.
Additionally, oddly, on that machine I can't access community.esri.com (I'm writing this on a different machine). Thank you for any help that can be rendered!
