How do I display routing directions on the map without clicking the mapView
I already have the routing coordinates in my code which are dynamic
I just want to display it on the map without clicking the map
Hi @ElohoKennedy, you have two options: RouteLayer and Directions widget, or just the RouteLayer.
You can dynamically update the Directions widget with programmatically created RouteLayers. Here's a blog and a demo covering this functionality. Routing directions are displayed inside the Directions widget:
https://www.esri.com/arcgis-blog/products/js-api-arcgis/developers/changing-directions/
https://noashx.github.io/blog/ChangingDirections.html
You could also just use the RouteLayer, and then handle the display of the directions yourself.
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-RouteLayer.html
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=layers-routelayer
To display the directions, you'll want to work with the results of RouteLayer.solve():
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-RouteLayer.html#solve
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-RouteLayer.html#RouteLayerSolveResult
https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-support-RouteInfo.html
Hope this helps!
