The DataTime fields are visible in a popup however currently in the Web Scene it isn't possible to use the DateTime fields in f.e. a query unlike the map viewer. To be able to query that kind of data you need to move/copy it into a text or number field. https://doc.arcgis.com/en/arcgis-online/create-maps/configure-layers-in-scene.htm#ESRI_SECTION1_31D2932008204BDEA6D330DDD0FFFE91
This is needed for Time based selections/visualizations and it's probably the first step before a Time Slider in 3D Web Scene integration would be possible.
is this possible yet...?
@Vlad Ok, I just tried on my end with my own multipatch data and i'm seeing the same thing. The doc isn't clear on this so i'd recommend posting a question in the Instant Apps channel so someone from that team can comment on this > https://community.esri.com/t5/arcgis-instant-apps-questions/bd-p/arcgis-instant-apps-questions
thanks,
Andrew
@Andrew--Johnson
Thanks for the reply. I've checked several times Instant App on the multipacth feature layer (groundwater levels) and the TimeSlider still doesn't work with it.
However, Map Viewer recognizes the DateTime field in the multipatch feature layer:
@Vlad DateTime fields are already supported on multipatch feature layers. While the Scene Viewer has not added the TimeSlider there is a new Instant App that has it. Checkout this blog for more details
https://www.esri.com/arcgis-blog/products/instant-apps/3d-gis/2035702-2/
Hi to all ESRI contributors\developers. Is there any plan to make it work with the multipatch layer? This seems very logical.
@BartFranken The scene layer package needs to have a DateTime field that can be read by the TimeSlider so that is why it's more of an ArcGIS Pro issue as it's authored from ArcGIS Pro. As far as the time slider is concerned i'll check with the Scene Viewer team and get back to you 🙂
@Andrew--Johnson thanks for the update. It's a bit confusing for me as this is Arcgis pro road map and an Arcgis Online issue but ok 🙂 Does that mean that the time slider is going to be implemented as well?
Thank you in advance!
We are currently working on time enabled scene layers and this is in the near-term roadmap for ArcGIS Pro and authoring scene layers.
https://community.esri.com/t5/arcgis-pro-documents/arcgis-pro-roadmap-june-2022/ta-p/1187498
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
