For my purposes (just using the api with a homebrewed ogr/gdal for data conversions) @dakcarto's gdal-filegdb formula works fine without dealing with compiler issues. Installing the api as a plugin seems to be the key.https://github.com/dakcarto/homebrew-osgeo4mac/issues/8 # Place FileGDB_API_1_3-64.zip archive in GDAL_THIRD_PARTY directory export GDAL_THIRD_PARTY= #/path/to/gdb-api-zipfile brew install gdal --enable-unsupported --with-postgresql brew tap dakcarto/osgeo4mac brew install gdal-filegdb export GDAL_DRIVER_PATH= #{HOMEBREW_PREFIX}/lib/gdalplugins
$ install_name_tool -change /usr/lib/libstdc++.6.dylib /usr/local/Cellar/gcc49/4.9-20131103/lib/gcc/x86_64-apple-darwin13.0.0/4.9.0/libstdc++.dylib /usr/local/lib/libFileGDBAPI.dylib $ install_name_tool -change /usr/lib/libstdc++.6.dylib /usr/local/Cellar/gcc49/4.9-20131103/lib/gcc/x86_64-apple-darwin13.0.0/4.9.0/libstdc++.dylib /usr/local/lib/libfgdbunixrtl.dylib $ otool -L libFileGDBAPI.dylib libFileGDBAPI.dylib: @rpath/libFileGDBAPI.dylib (compatibility version 0.0.0, current version 0.0.0) @rpath/libfgdbunixrtl.dylib (compatibility version 0.0.0, current version 0.0.0) /usr/local/Cellar/gcc49/4.9-20131103/lib/gcc/x86_64-apple-darwin13.0.0/4.9.0/libstdc++.dylib (compatibility version 7.0.0, current version 52.0.0) /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 159.1.0) $ otool -L libfgdbunixrtl.dylib libfgdbunixrtl.dylib: @rpath/libfgdbunixrtl.dylib (compatibility version 0.0.0, current version 0.0.0) /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 159.1.0) /usr/local/Cellar/gcc49/4.9-20131103/lib/gcc/x86_64-apple-darwin13.0.0/4.9.0/libstdc++.dylib (compatibility version 7.0.0, current version 52.0.0)
$ ogrinfo Misc.gdb ogrinfo(81745,0x7fff797e2310) malloc: *** error for object 0x10d219de0: pointer being freed was not allocated *** set a breakpoint in malloc_error_break to debug Abort trap: 6
ogrinfo(45386,0x7fff74779310) malloc: *** error for object 0x10b49dde0: pointer being freed was not allocated *** set a breakpoint in malloc_error_break to debug
$ brew tap homebrew/versions $ brew install --enable-cxx gcc49
dyld: lazy symbol binding failed: Symbol not found: __ZN10FileGDBAPI17DeleteGeodatabaseERKNSt3__112basic_stringIwNS0_11char_traitsIwEENS0_9allocatorIwEEEE Referenced from: <file> Expected in: flat namespace dyld: Symbol not found: __ZN10FileGDBAPI17DeleteGeodatabaseERKNSt3__112basic_stringIwNS0_11char_traitsIwEENS0_9allocatorIwEEEE Referenced from: <file> Expected in: flat namespace
�?? nm -g libFileGDBAPI.dylib | grep DeleteGeodatabase 00000000000010b2 T __ZN10FileGDBAPI11Geodatabase17DeleteGeodatabaseEv 0000000000006260 T __ZN10FileGDBAPI17DeleteGeodatabaseERKSbIwSt11char_traitsIwESaIwEE
We will take a look. Can you provide more information. What errors are you seeing when you attempt to build gdal.
It appears that the available binary API is not compatible with the new OS X 10.9 Mavericks. Can anyone else confirm or deny this? I am unable to build gdal support for FileGDB, and I suspect it is due to changes in the available libs in 10.9 versus older OS versions.
