tried fussing with inputting filename backslashes as either "\" or "\\", didn't help.
lyrFAC = "lyrFAC" lyrFDIR = "lyrFDIR" gp.MakeRasterLayer(flow_acc,lyrFAC) gp.MakeRasterLayer(flow_dir,lyrFDIR) expr = "con(%s <= %s, %s)" % (lyrFAC,1100,lyrFDIR) gp.SingleOutputMapAlgebra_sa(expr,flowdir_channels)
In general I've found them inconvenient because they don't exist anywhere that I can look at them while debugging or just tracing my algorithm's results
E:\work\test1>dir /x Directory of E:\work\test1 06/05/2012 03:42 PM <DIR> . 06/05/2012 03:42 PM <DIR> .. 06/05/2012 03:39 PM <DIR> testa1 06/05/2012 03:40 PM <DIR> TESTBV~1 testbverylongname 06/05/2012 03:42 PM <DIR> TMP_RI~1 tmp_rios_preproc2 0 File(s) 0 bytes 4 Dir(s) 92,880,891,904 bytes free
# Early in script, define hydrology layers, global variables - this code has been used and re-used for years and worked fine on all Arc versions outputws = gp.workspace + os.sep + "Output" + os.sep Hydrows = outputws + "Hydro_layers" + os.sep if not gp.exists(Hydrows + "flow_dir"): # Create flow direction raster gp.FlowDirection_sa(DEM, Hydrows + "flow_dir", "NORMAL") flow_dir = Hydrows + "flow_dir" if not gp.exists(Hydrows + "flow_acc"): # Create flow accumulation raster gp.FlowAccumulation_sa(Hydrows + "flow_dir", Hydrows + "flow_acc", "", "FLOAT") flow_acc = Hydrows + "flow_acc" # Later, set flow direction raster to null where there are streams def define_channels(): try: gp.AddMessage("\nDefining flow direction channels...") exp = "\"VALUE\" > " + str(int(threshold_flowacc)) # THIS IS WHERE THE ERROR OCCURS gp.SetNull_sa(flow_acc, flow_dir, flowdir_channels, exp) # ALTO TRIED THIS gp.SingleOutputMapAlgebra_sa("CON(" + flow_acc + " <= " + threshold_flowacc + ", " + flow_dir, ")", flowdir_channels) except: gp.AddError ("\nError defining flow direction channels: " + gp.GetMessages(2)) raise Exception
When SetNull runs, I get this error - the path is totally garbled:
