I am attempting to use contingent values in Field Maps from a hosted feature service within the AGO environment. I've set up the contingent values in ArcGIS Pro 2.9.3, and everything seems to be working fine in the Pro environment. However, when I publish to hosted feature service in AGO and then test in Field Maps, it reverts to the full domains, rather than the contingent values. I was under the impression that if I set it up in Pro, it should just "work" once I publish to AGO. Am I missing something?
When I look at the REST endpoint of the layer, Has Contingent Values = True. So that looks okay, but it's not propogating to the webmap or Field Maps.
