Hello ESRI,
Could you share the code of the widget below please. it is is the builder (top right). I think it could be pretty good to have a very good authentication widget in our Experience Builder Apps.
Thanks.
Thank you very much @henrilebon974 . I will try to implement this.
You can add it in a widget like this.
Hi. Can you share methodology how to implement this. Thanks
Thank a lot Doug. I'm going to try that.
@henrilebon974,
After digging, I found this (undocumented) component:
import { UserProfile} from 'jimu-ui'; <UserProfile className="left esri-header-account-image" portalUrl={this.props.portalUrl} user={this.props.user} helpUrl={this.props.config.helpUrl || this.props.portalUrl} > </UserProfile>
It will pull the current user, icon, etc from the active session and update through state changes.
For initial login, use the SessionManager:
onSigninClickHandler = () => { let sm = SessionManager.getInstance(); sm.signIn(); }
Best of luck!
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
