Add, with the right clic menu, a refresh map series to be more intuitive than looking at the bar small icon. Personally I put it just before Properties like "Refresh Map Series".
Hi, maybe in v3 it will be done but, in a map series pages, if we had a map in the series define by a polygon layer it's not automatically added to the list.
So, at least add a refresh, in the right clic, if it's not possible to do that automatically.
For now, I have to change the field use for the map, then return to that field to see the new map available.
@MarcelSt-Germain
Are you saying that the map series doesn't refresh if you add a polygon to the index layer?
If that is what you're asking, could you try Refresh Map Series?
If you are talking about something else, please provide more details and screenshots so that we can better understand the idea. Thanks!
Hi Kory,
Sorry, your right, I forgot about the button, it's working.
But the idea of adding this refresh on the right clic menu still good and more intuitive. Personally I put it just before Properties like "Refresh Map Series".
Now still waiting to see if a real map series for annotations will be available in v 3
Thanks, Marcel. Since the refresh functionality for map series already exists, in order to re-open this idea, it will need to be more specific. Can you modify this idea's title to "Add Refresh Map Series option to the layout context menu" ?
And update the ideas description to reflect that the request is to add the command to the context menu?
Once that is done we can re-open the idea.
Thank you!
This was added in ArcGIS Pro 3.3.
Funny but since 3,3 is bug, I will have to wait for an other version. Maybe one day.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer je gratis.
