After thinning pathway, do all pathways with their end touch POIs? We find a lot of thinned pathways do not touch POIs at their ends when we magnifiy the result to take a close look. Is it normal? Thanks
Hi Annina,
Thanks for your reply. The problem hasn't been solved. Result of web pulishing is fine but I want to know if there is anyway to make the POIs lying on the thinned Pathway in AIIM. All the data on the same projection.
Best regards,
NCW
Do you still have this problem?
Just wondering, is your map and all the data on the same projection when you run the thin pathways tool / or when checking the data?
Does the check with the Service Area network solve correctly? Did you do a test publishing of the network and the webmap and try to find directions between the POI in the Web App?
I'm sorry that my description of the problem is not clear. Actually, the problem is that POIs are not on the thinned pathways. A lot of POIs are just beside the pathway like the photo in the link below. I wonder if this is because pathways have to be on lattice and lattice generation may not be able to pass through all POI. Is my observation correct? Thank you. https://flic.kr/p/2nsuLQv
