Why does this happen (attached pic)? Workaround is to export the features to a new feature class and then bring it back into the GDB. The original FC had 21 features but after export only 17 remain. So I am assuming Pro has problem with these 4 features but doesn't mention it in the error message. How can this be avoided.
Sincerely
Doesn't open in ArcMap either. It is a File GDB. And problem is not in columns but with rows. 4 rows do not comeback after FC is exported. So I am assuming that these 4 records have some problem. But pro doesn't point to anything.
Another thing to check is to see if any of your column names contain a bracket. ArcMap can handles these but ArcGIS Pro cannot.Question for you - are you using a file geodatabase or enterprise geodatabase?
strange, the error messages leads to this
BUG-000106410: Sorting a hosted feature layer on a Domain field and.. (esri.com)
try compressing your data source and try it again. Look at your feature attribute table. do all features have geometry?
