I want to know How can I change the pin location image in map? I want to give my custom image as shown in image
I'm not sure of the answer but you could try setting the highlight option property on the Map View
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#highlightOptions
You don't say what kind of layer you're using or how you're adding it the map but a picture marker symbol will allow you to specify a custom image.
The Symbol Playground will help you generate the correct syntax.
How to use picture mareker symbol
Can you show where to add picture marker symbol. When I am trying to use it it gives me an error
I haven't tested it out but you could try something like
//create the marker
var marker = {type: "picture-marker",url: "https://arcgis.github.io/arcgis-samples-javascript/sample-data/cat3.png",width: 46,height: 46};
//apply it to each graphic
const peakResults = response.features.map(function(feature) {feature.symbol = marker;}
Hi,It's working, thanksDo you know how to change the picture marker symbol on click the pin image.Like the below image when I click the pin image it should change to dark red marker.
It's working ,thanks. I need few more suggestions.To change the picture marker dynamically after on click.
I believe you need to watch for a click event on the MapView object and get the graphic using a hit test.
This sample should get you started -
https://developers.arcgis.com/javascript/latest/sample-code/view-hittest/
It adds a highlight on mouse-over but you could modify it to change the symbol on click instead.
I tried with the hit test and click event but still it's not working. I will share my code also.
let centroidRenderer = {type: "simple",symbol: {type: "picture-marker",// url: "https://static.vecteezy.com/system/resources/previews/000/582/855/original/vector-location-pin-icon.jpg",url: "images/Location-map.png",width: "26",height: "26"}};
let locationpin = new FeatureLayer({url:"https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Centroids/FeatureServer/0",renderer: centroidRenderer});
let symbol;
view.when(async () => {const layerView = await view.whenLayerView(locationpin);view.on('click', async (e) => {const {results} = await view.hitTest(e);try {const { graphic } = results.find(x => x.graphic.attributes.OBJECTID);if(symbol.url=="images/Location-map.png"){(symbol.url==" https://static.vecteezy.com/system/resources/previews/000/582/855/original/vector-location-pin-icon.jpg")}else{symbol.url==" images/Location-map.png"}// fWidget.graphic = graphic;symbol = layerView.highlight(graphic);} catch(err) {}});});
view.when(function() {map.addMany([locationpin]);});
What is not working? Are you getting an error? Are you not getting any features from the hit test? Or is the symbol not being applied?
