I have a question about the use of terminals and devices.
Terminals can allow the discerning of different outputs from a single device for tracing operations and subnetworks definition, like a transformer and its downstream outputs lines (max 7 lines). But for managing the various outputs, for example, in order to have one output line 'on' and one other line 'off', is it mandatory to add an additional device to do that for each line?
This is what I have understood from the online material and frequently-asked-questions, like the question and answers below: Do I need to convert my unit records into features? Only if a single unit feature has a different device status then other unit features in the same device. For example, if a non-gang operated three-phase switch has one of the three switches open, then this case should be migrated as three individual switches. If no cases like this exist in your data, then you can migrate the unit records to the ElectricDeviceUnit table
Please let me know.
