After exporting a polygon from ArcGIS Pro to a PDF with a high number of vertices (>32k) and then opening the file in Adobe Illustrator, the polygon is rendered incorrectly (Figure 1).
Adobe Illustrator has a limit on the number of vertices within a single path-polygon. ArcMap cuts these large polygons into smaller pieces when exporting to PDF, and these are rendered correctly in Adobe Illustrator (Figure 2).
I propose that the Export to PDF function in ArcGIS Pro should be able to perform a similar slicing of polygons with an excess number of vertices.
