I get an error message (see attachment) when attempting to calculate the geometry for certain point features when using ArcPro. Other point features will calculate geometry successfully.
In the mean time perhaps you could export the feature class to a different database and see if the error persists.
Sometimes when I have had an issue I have exported the feature class and truncated the original and re-loaded it to solve a problem
However, not always a possible or viable option.
We used to get an issue every now and then with ArcMAP where it would create phantom rows in the database. i.e. when you delete a feature it actually retains it in the database until you compress it.
That phantom row would sometimes cause erroneous issues such as this.
Our SDE Enterprise Databases are now set to compress every day sometime after midnight.
I would also check to see if you have any multipart features.
compress your database and try again.
Thanks for the reply. Different feature classes. Meters and fittings work when calculating geometry, but valves and hydrants won't. Another oddity is that this error only occurs when using Pro. All features geometry can be calculated in ArcMap.
I don't have write access to the feature classes, but our DBA is looking into the RepairGeometry tool you suggested.
Please share a screenshot of your tool parameters, that might make troubleshooting easier.
Do you mean feature classes, as in "feature class 1 works, feature class 2 does not"? Or do you mean actual features as in "this point works, but this point in the same feature class does not"?
Things to check off the top of my head:
