Chris Fox at Esri just kindly posted this example of using python to generate dynamic text outside of the data driven pages/index layer model:Below is a sample, this assumes i have a map document, two text elements in the layout, a layer named TestLayer with 2 fields "AddressField" and "ZipField".import arcpy# get the reference to the map document and the layer named "TestLayer" in the map documentmxd = arcpy.mapping.MapDocument("C:/Temp/Test.mxd")mapLyr = arcpy.mapping.ListLayers(mxd, "TestLayer")[0]# get the reference to the text elements in the map document. I have 2 text elements with the name Address and ZipaddrElem = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "Address")[0]zipElem = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "Zip")[0]# create a cursor and grab the first row in the feature class for the layer specified aboverows = arcpy.SearchCursor(mapLyr.dataSource)row = rows.next()# set the text property of the text element equal to the value from the fields named "AddressField" and "ZipField"addrElem.text = row.getValue("AddressField") zipElem.text = row.getValue("ZipField")# save the map document and delete the reference to the row, cursor and map objectmxd.save()del mxd, row, rows,
Is there a way to use python in a dynamic text where it looks for the dynamic text by attribute and depending on that value, you place and if else. If attribute = 0 then "No", else "Yes"?
