Hello I have table with huperlink field in ArcGISPRO, I need that this hyperlink will work in Portal for ArcGIS also.
Is it possible?
regards,
Anzhelika
Can you give an example of the contents of this field? Portal can handle hyperlinks just fine, but they typically need to be http:// or https://, otherwise Portal re-writes the URL. Have you attempted to add these URLs to Portal and seen different results?
My link is to file Server. that why I didn't use https
Anzhi
UNC filepaths will not work through a web map.
