Hi everyone,
I am trying to create a list of tabs in a story map page very similar to this link:
https://www.w3schools.com/bootstrap/tryit.asp?filename=trybs_tabs_dynamic&stacked=h
For some reason the <li><a data-toggle="tab" href="#menu3">Menu 3</a></li> lines become after saving the project
<li><a href="#menu3" target="_blank">Menu 3</a></li> which opens a new tab when the user clicks a tab. Is there a workaround this?
I see. Story Map actions are a priority so I guess the closest solution would be to list everything in order on the page instead of tabs.
Thank you Owen
I don't believe it's compatible with standard browser web security policies for content within an iframe to communicate with the parent page in that way. There might be a way to trigger a story action by implementing some cross-frame messaging via a postMessage API, but that's beyond my expertise. You'd have to work with a developer who has a deep understanding of security.
Thanks Owen, yes I am using the Map Journal on Enterprise.
I have tried using <iframe> to emded my html and the content is tabbed except is there a way to initiate map story actions through the embed htmls?
Eg. I have a text in one of the tabs with a specific action
<a data-storymaps="MJ-ACTION-1651162466736" data-storymaps-type="media" href="#"
The data-toggle attribute is not on ArcGIS Online's supported HTML allow list (see Supported HTML—ArcGIS Online Help | Documentation), so I believe that's why it's getting removed. There might be a different way to create the experience you want without using that attribute, or you could host your code on your own web server and embed it into the story.
I moved the question to the classic questions board since I believe you are working with one of the classic storytelling templates like Journal or Series.
