A new bug in 4.23 causes the MapView.zoom property to read incorrectly as -1 when the (1) constraints.lods and (2) extent properties are specified in the constructor. I noticed this new section titled “Zoom and LODs” appeared in the 4.23 documentation, but I’m not doing anything contrary to it to warrant this issue.
To view this in action, go to the Sandbox for the “Into to MapView – Create a 2D map” sample. When there, change this code:
const view = new MapView({
container: "viewDiv",
map: map,
zoom: 4,
center: [15, 65] // longitude, latitude
to this (it's a little long, but mostly just LODs):
map: map,
constraints: {
lods: [
level: 0,
resolution: 156543.033928,
scale: 591657527.591555,
alias: "World (1:591,657,527)"
level: 1,
resolution: 78271.5169639999,
scale: 295828763.795777,
alias: "World (1:295,828,763)"
level: 2,
resolution: 39135.7584820001,
scale: 147914381.897889,
alias: "World (1:147,914,381)"
level: 3,
resolution: 19567.8792409999,
scale: 73957190.948944,
alias: "Continent (1:73,957,190)"
level: 4,
resolution: 9783.93962049996,
scale: 36978595.474472,
alias: "Continent (1:36,978,595)"
level: 5,
resolution: 4891.96981024998,
scale: 18489297.737236,
alias: "Countries (1:18,489,297)"
level: 6,
resolution: 2445.98490512499,
scale: 9244648.868618,
alias: "Country (1:9,244,648)"
level: 7,
resolution: 1222.99245256249,
scale: 4622324.434309,
alias: "States / Provinces (1:4,622,324)"
level: 8,
resolution: 611.49622628138,
scale: 2311162.217155,
alias: "Counties (1:2,311,162)"
level: 9,
resolution: 305.748113140558,
scale: 1155581.108577,
alias: "Counties (1:1,155,581)"
level: 10,
resolution: 152.874056570411,
scale: 577790.554289,
alias: "County (1:577,790)"
level: 11,
resolution: 76.4370282850732,
scale: 288895.277144,
alias: "Metropolitan Area (1:288,895)"
level: 12,
resolution: 38.2185141425366,
scale: 144447.638572,
alias: "Cities (1:144,447)"
level: 13,
resolution: 19.1092570712683,
scale: 72223.819286,
alias: "City (1:72,223)"
level: 14,
resolution: 9.55462853563415,
scale: 36111.909643,
alias: "Town (1:36,111)"
level: 15,
resolution: 4.77731426794937,
scale: 18055.954822,
alias: "Neighborhood (1:18,055)"
level: 16,
resolution: 2.38865713397468,
scale: 9027.977411,
alias: "Streets (1:9,027)"
level: 17,
resolution: 1.19432856685505,
scale: 4513.988705,
alias: "City Block (1:4,513)"
level: 18,
resolution: 0.5971642835598172,
scale: 2256.994353,
alias: "Buildings (1:2,256)"
level: 19,
resolution: 0.29858214164761665,
scale: 1128.497176,
alias: "Building (1:1,128)"
level: 20,
resolution: 0.1492910708899543,
scale: 564.248588,
alias: "Houses (1:564)"
level: 21,
resolution: 0.0746455354449772,
scale: 282.124294,
alias: "Houses (1:282)"
rotationEnabled: true,
snapToZoom: true
extent: {
xmin: -17576195,
ymin: 2427634,
xmax: -17573701,
ymax: 2429488,
spatialReference: { wkid: 3857 }
view.when(function () {
alert(view.zoom);
view.notifyChange("zoom");
alert(view.zoom);
Then click the Refresh link at the top right of the page. You will see two alerts: -1 and (probably) 15.
To see that this is specific to 4.23, go to the top of the code, and change the “link” and “script” tag urls to use 4.22 instead. After clicking Refresh again, you’ll receive two more alerts: 15 and 15. This demonstrates that what once worked in 4.22 no longer works in 4.23.
When I usually report these things, I try to show where in the API the problem happens, but I’m not able this time. However, I do have a workaround for AMD-based solutions with a locally hosted API.
In esri/views/MapView.js, search for:
this._set("ready",!0)and then replace with:
this._set("ready",!0);this.notifyChange("zoom")
