This is a follow-up question for this post https://community.esri.com/t5/arcgis-survey123-questions/extract-field-and-concatenate/td-p/1163997
The formula in the calculation column of the URL field is correct
concat(string('https://councildocs.dsm.city/rollcalls/')+${InitContrYrRollCallYr},'/'+${InitContrYrRollCallNbr}+string('.pdf'))
This is the preview in Connect's form
But when you view the data in the feature service, the data is different.
That's a text field with 255 characters.
Any ideas why it works in Connect but not in the webform?
Thanks.
You cannot use the + on strings in the web form. You can only use concat. No need for the string() part.
Just concat(string1, string1, ...)
That worked, thanks!
