Hallo iedereen,
Is er een manier om SDE-lagen binnen de ArcGIS Map-component voor Power Bi weer te geven?
Of zijn we beperkt tot het weergeven van standaard basiskaarten?
Bedankt
Hello @SanchezNuñez !
You can add Feature Layers and Map Services as reference layers to see them in the map, but there is no direct connection to SDE.
Is there a certain dataset or workflow you want to accomplish? If we know more we can suggest workflows to help support you.
Cheers,
Andrew
Hi Andrew,
Thank you for your answer. We are looking for a way to show the utility network as background layers in a Power Bi Map Visualization control.
With Power BI ArcGIS Maps for GIS control we connected with AGOL and when we select in AGOL the application "ArcGIS for Power Bi" we get the error message below. See attached screenshot.
What are we missing?
Thank you for choosing Microsoft Power BI
Let's get you startedWe can't finish signing you up as.
It looks like Microsoft Power BI isn't currently available for your work or
