When I try to log in ArcGIS Maps for Adobe CC in Illustrator using my ArcGIS Online account, it shows Invalid redirect_uri Error 400 before asking for my username and password. The workaround I found only referred to Portal environment. Have you seen this behavior when using ArcGIS Online login?
https://support.esri.com/en/technical-article/000015445
Thanks!
Hello @Boyang_Wang
Sorry for the inconvenience. While the team has difficulty reproducing the same issue in-house, a possible workaround could be deleting the config.json file from your user profile folder. The file is located at
C:\Users\USERNAME\AppData\Roaming\m4cc\config.json (Windows)
~/Library/Application Support/m4cc/config.json (macOS)
Please let us know if the workaround doesn't help.
Xingdong
Maps for Adobe Team
@Boyang_Wang, I was getting that error too when I tried signing in with my Portal credentials and then got an error that I wasn't authorized to access my organization's Portal through Maps for Adobe. After that failed login, even when I tried to login to my ArcGIS Online account, it would give me the error you described. But I just tried deleting the config.json file, as @Xingdong_Zhang suggested, and it resolved the issue. Thanks!
@Xingdong_Zhang
Your method made it work. Now I can use ArcGIS Online login. Many thanks!
p.s. I did try uninstalling m4cc but it seems that this config.json was never deleted.
Boyang
I got some troubleshooting suggestions from an Esri technician. Can someone help me to narrow down if you have experienced this issue? I didn't expect to reset windows...
- Check all the applications installed especially applications that are related to network connection such as VPN, AntiVirus and etc.- Perform Windows Update, Update all the drivers in your machine.- Check the Windows Firewall and make sure there it is not blocking any site from your end.- If the issue persists, then you can consider resetting your windows.
