Hello,I have a simple question. When you create a ProWindow, is it possible to set its snapshot to load on click? Rather, maybe some position setting on the screen.
Thank you for answerDavid
How to handle loaded event in WPF here:
https://docs.microsoft.com/en-us/dotnet/desktop/wpf/advanced/how-to-handle-a-loaded-event?view=netframeworkdesktop-4.8
You can set ProWindow position in xaml or in code. ProWIndow is derived from Window.
In xaml you can use WindowStartupLocation:
<controls:ProWindow x:Class="YourWindowView" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:controls="clr-namespace:ArcGIS.Desktop.Framework.Controls;assembly=ArcGIS.Desktop.Framework" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:extensions="clr-namespace:ArcGIS.Desktop.Extensions;assembly=ArcGIS.Desktop.Extensions" mc:Ignorable="d" Title="Window name" MinWidth="550" WindowStartupLocation="CenterOwner" d:DataContext="{Binding Path=vm.YourWindowViewModel}" SizeToContent="Height" Width="550" >
It has few alternatives. More info here:
https://docs.microsoft.com/en-us/dotnet/api/system.windows.window.windowstartuplocation?view=netframework-4.8
In code you can do like this:
var window = new YourProWindow(); window.Left = 100; window.Top = 100; window.ShowDialog();
Thank you!
