Hello allI am trying to combine three fields for webservice to one field and show it on table in dashboard. I don't know if this is possible or not for now or I can use Arcade for this. I don't want to add field to data.
This is definitely possible, but you'll need to use a Data Expression. You can see some examples here that may be helpful to you.
Can you elaborate on what these fields look like? When you say "combine", do you mean you want to aggregate the values in some way, or are they just text that you want to merge together?
something like this in one fields:
all fields are string and in one table. I am using table widget in dashboard
Not sure if this will work, but it's a starting point. You basically need to run through your features and concatenate those values for each, then push the features into a new FeatureSet.
// connect to layer var fs = FeatureSetByPortalItem( Portal('your-portal-url'), 'itemID of your layer', 0, // or whatever layer index it is ['*'], // you can limit the incoming fields to improve perfomance if you like false ) // get schema for layer var out_fields = Schema(fs)['fields'] // add a new field to the schema to hold "merged" data Push( out_fields, {name: 'aidbidcid', alias: 'Aid, Bid, Cid', type: 'esriFieldTypeString'} ) // Use updated schema to create new dict var out_dict = { fields: out_fields, geometryType: '', features: [] } // Iterate over features and concatenate new field, populate output dict for (var f in fs){ // Create dictionary from existing attributes var atts = Dictionary(Text(f))['attributes'] // Array of fields to concatenate var ids = [ f['Aid'], f['Bid'], f['Cid'] ] // add new attribute to dictionary atts['aidbidcid'] = Concatentate(ids, ',') // push feature to output dict Push( out_dict['features'], atts) } Return FeatureSet(Text(out_dict))
