Hi there,
I have created a feature layer in ArcGIS online and am now trying to change field inputs from e.g. "fixed" value to "button user input", however when I press save it won't save the changes.
I am new to ArcGIS and might have missed something. I am following this guide:https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/get-started-quickcapture/#online and this one https://doc.arcgis.com/en/quickcapture/help/editproject.htm.
Any help would be greatly appreciated!
Best wishes,
Tamara
Hi @TamaraKartal From the field's drop-down menu, you will select the 'Button user input' option and create a button user input variable first, and then assign it to that text field. This article might be more helpful to you https://community.esri.com/t5/arcgis-quickcapture-blog/understanding-user-inputs-in-arcgis-quickcapture/ba-p/892208 If you still see the problem, please document your steps so we can better help to figure out what was missing. Thanks!
Hi I am also having this issue and have tried following the tutorial with no resolution.
Thank you so very much!! It worked now.
