Could an Arcade function be added that would explode geometries into separate lines for each segment?
That would be helpful when doing complex analysis on polyline segments.
MultiPartToSinglePart
@JohannesLindner @Thanks, what I meant was: explode a given polyline part into multiple 2-vertex segments (split at each vertex).
Split Line At Vertices (Data Management)—ArcGIS Pro | Documentation
but then you would be getting into Arcade having different license levels
I don't know... Seems like a quite narrow use case to make a function for. Plus, you can easily do it yourself:
function explode_polyline(geo) { var segments = [] for(var p in geo.paths) { for(var q = 1; q < Count(geo.paths[p]); q++) { var point0 = paths[p][q-1] var point1 = paths[p][q] Push(segments, Polyline({"paths": [[point0, point1]], "spatialReference": geo.spatialReference})) } } return segments } Console(explode_polyline(Geometry($feature)))
@JohannesLindner Fair enough.
@KoryKramer, feel free to close. Cheers.
As noted, each segment can be obtained by looping through the vertices of the geometry.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
