I need to have a draggable marker on the map something like how it is working in the example below -
https://developer.here.com/documentation/examples/maps-js/markers/draggable-marker
Hi @ReneRubalcava,
I am trying in indoor map on floors, if I do drag and drop on floor it is going to ground floor, How can I place on floor.
Thanks!
Krishna
You'd need to add some logic to handle when you click to start moving it and click to stop. Here's an updated demo.
https://codepen.io/odoe/pen/VwVrxBJ?editors=0010
if (pause) { handlers.forEach((a) => a.remove()); handlers.length = 0; pause = false; return; };
@ReneRubalcava how would you make the marker draggable without having to "long press" (hold) the marker? I'm looking for standard marker drag/drop behavior (hover over marker, get pointer, click and drag marker).
Here is a sample of how to do this on a hold event.
https://codepen.io/odoe/pen/bLEroK?editors=0010
view.on("hold", ({ mapPoint }) => { view.hitTest(view.toScreen(mapPoint)).then((hitResult) => { if (!hitResult.results[0].graphic) return; console.log("hold event, now drag mouse to move graphic"); pointGraphic.symbol = selectSymbol; const pausePan = view.on("drag", stop); const move = view.on("pointer-move", updateGraphic); const up = view.on("pointer-up", cleanUp); handlers.push(pausePan); handlers.push(move); handlers.push(up); }); });
