Using ArcGIS API for JavaScript 4.x I am trying to create custom behavior for the Editor Widget. Specifically I want to watch for clicking the Add button on the create workflow or when clicking either Update or Delete on the update workflow. I am trying to use the editor.on() event handler, however, I am not seeing a list of events for the Editor widget. Other widgets, such as Search, have an Event Overview list (https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Editor.html#events-summary) but there does not seem to be one for Editor (https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Editor.html#events-summary).
A point in the right direction would be appreciated.
you need to use the .on or .watch in the editor.viewModel , there are 2 sub viewModels inside that tooeditor.viewModel.featureTemplatesViewModeleditor.viewModel.featureSketchViewModelthis will trigger on all editor states, you can check which event you need to trigger your custom code
editor.viewModel.watch("state", function (state) { console.log(state);});
or you can be more specific like this:
editor.viewModel.featureTemplatesViewModel.on("select", (x) => { console.log(x);});
editor.viewModel.featureTemplatesViewModel.on("select", (x) => { console.log(x);});is not working. I'm using JS API 4.28. What is the right property and right model to watch for?
