Friend Sub DeleteObject(ByVal pInObject As Object) Dim Delete As New ESRI.ArcGIS.DataManagementTools.Delete Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2 Try Using releaser As New ESRI.ArcGIS.ADF.ComReleaser releaser.ManageLifetime(Delete) Delete.in_data = pInObject Result = RunTool(Delete, Nothing) If Result Is Nothing Then System.Windows.Forms.MessageBox.Show("Could not delete object") End If End Using Catch ex As Exception System.Windows.Forms.MessageBox.Show(ex.ToString, "Delete error") End Try End Sub Private Sub ReturnMessages(ByVal pResult As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Title As String) Dim ErrorMessage As String If pResult.MessageCount > 0 Then For Count As Integer = 0 To pResult.MessageCount - 1 ErrorMessage += pResult.GetMessage(Count) Next End If System.Windows.Forms.MessageBox.Show(ErrorMessage, Title) End Sub Friend Function RunTool(ByVal Process As ESRI.ArcGIS.Geoprocessor.IGPProcess, ByVal TC As ESRI.ArcGIS.esriSystem.ITrackCancel2) As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2 Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2 Try Result = CType(GP.Execute(Process, Nothing), ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2) If Result.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then ReturnMessages(Result, "Geoprocessing Error") GP.ClearMessages() Catch ex As Exception ReturnMessages(Result, "Fail") System.Windows.Forms.MessageBox.Show(ex.ToString, "Run Geoprocessor") End Try Return Result End Function
