hey there we have installed arcgis enterprise portal 10.9.1 the portal is extremly slow and it's get more slower after using a cloudflare proxy on the domain name any idiea ?
Do you mean it's slow from outside on the Internet when going through the proxy? If that's the case, it's really easy to turn off proxying for that entry in Cloudflare and see if the problem goes away. That would be the first thing I would do.
If you mean it's slow on your internal network when Cloudflare is running then you should be setting up an internal DNS to resolve the name locally. That is, when you hit the URL it should not be giving you the outside IP address because there is no reason to do that.
When I am outside, my host name resolves like this, a non-routable internal address
bwilson@cc-TestMaps:~$ dig geoserver.wildsong.biz ... geoserver.wildsong.biz. 300 IN A 104.21.42.186 geoserver.wildsong.biz. 300 IN A 172.67.208.22
Local:
(base) bwilson@bellman:~/.ssh$ dig geoserver.wildsong.biz ... geoserver.wildsong.biz. 0 IN A 192.168.123.2
If you are getting a Cloudflare proxy address on your internal network then the packets for a request to your own server go out, through a Cloudflare proxy cache server, then back into your network, then back to Cloudflare then back to your client.
Yes, when i turn off the proxy it’s back to normal but i use it for security because it’s hide my real ip i dont have a proplem with my internal network when access from inside the network I’m talking about the out side users
Interesting so maybe you want to try this... I wonder how long "Temporarily" is -- maybe until you turn it back on? This affects the entire domain, which might or might not be bad for you. The popup when you turn it on says (in part) "Cloudflare will continue proxying traffic to your origin server without caching any content."
If "Development Mode" fixes it then you can put in up to 3 Page Rules per domain in the free level of Cloudflare service. (Assuming you like me use the free level!) Then you can set "Cache Level" to "Bypass Cache". I look forward to hearing if this works.
i already tried that but i noticed the latency is very high when requesting web page files and scripts
Yes WHOA that's bad. Now I have to test this to see what it does to me! Looks like you are hitting a WAB app.
Old post, but not finding much newer about Cloudflare. Did you ever get this resolved, are you still using Cloudflare?
I can't find much about Cloudflare and ArcGIS.
