The ArcGIS IPS workflow requires sharing an editable web map to either an ArcGIS Online or ArcGIS Enterprise portal. It is crucial that the IPS tables in this map are editable as the ArcGIS IPS Setup app will need to populate them.
The IPS tables in the shared webmap will not be editable if
The attached document describes a manual workaround to this issue.
