I'm making a map where people can search an address to see what it is zoned for. Is there a way to make this happen without geocoding and using a lot of credits? I'm looking for some kind of work around if possible.
Yes I do have address info in the parcel data! I didn't realize I could modify the search widget in this way, thank you so much I will try that 🙂
Right... so you are using the world geolocator to find the address which will only return an address point. Do you have the address information in your parcel data? If so, you can modify the search widget to use the situs address in your parcel data instead of the world geocoder.
I am posting as a web map! I am making a trash and recycling map and would like residents to be able to plug in their address and have it zoom to their parcel and display their info in the pop up. Currently if they search the address it takes them to it, but doesn't auto select the parcel and automatically do the pop up.
this is what I have
https://williamstongis.maps.arcgis.com/apps/webappviewer/index.html?id=57ccbab43df148aeae932e33f554ddb3
Hello K,
Are you publishing the map as a web map? What data and infrastructure are you using?
